intermitant ABS light after new birf install
Hi all.
After installing my new Slee birfs and re-using my OEM exciter rings, everything was fine for two days. Now I have an intermitant ABS light that has come on and off on for the last couple of miles. Its parked now. Should I be worried about driving it? The only thing I can think of that would cause this is if one of the rings fell off.
I am at work now but will investigate any suggestions when I get home this evening.
Having a ring not all the way on can do this...wobbling causes it. Other issues can be if there was any metal bits on the sensor. The sensor is easy to test, you can pull it with little effort. The ring may be a bit more tricky, for obvious reasons.
If it is not all the way on you need to get it back on...only way to get a new ring is to mooch one from someone else or buy a whole birfield.
If the ring fell off I think you'd know before you had an ABS light... :eek:
Check the sensor. Clean the metal end. Check the connector.
I did not know Slee made birfs. Cant seem to find them on the site either. Could you enlighten me?
Karl
Thanks guys. I'll pull the sensor and give it a once over. I know I got the rings on right and straight so I don't see how they could have come off.
Regarding the Slee Birfs, I didn't know they sold them either but I called to see what they had and it appears that they do carry an aftermarket Japanese made birfield that is supposed to be manufactured exactly like the OEM (as far as the metal tempering is concerned). There is quite a cost savings as they are $250 each. Cheaper than Longfields, almost as cheap as EBAY and to top it all of Slee recommends them.
