Interior light bracket
Which Bracket is better?
  • bracket in pic #1 is better design
    Votes: 7 70.0%
  • bracket in pic #2 is better design
    Votes: 3 30.0%
  • other?
    Votes: 0 0.0%
  • Total voters
    10
JohnnyC
昔は TLCA2231 Order of the Pinion Shaft (OoPS)
Sire John @ UpState Ny & Wells Me
I made this simple bracket for my oem hardtop light that I got from BigRedFj40 ;)
then tried alil different of a bracket..so which looks better
pic #1 exposed bolts with the light moved out...
or
pic #2 hidden bolts with light moved in
I made interior lights by running a wire through my roll bar to a couple of festoon lamp holders on the bottom of my roll bar. These are just above and behind the driver and passenger...not a ton of light but they stay with the crusier when the top is off and no wires anywhere.
Dwight
Number two looks clean, but can you move the left edge of the bracket to match the edge of the B-column?
I could make the bracket a lil longer to meet the end of the pillar...the light cant go any further...because it hits the main bow...
good idea :)
...but they stay with the crusier when the top is off and no wires anywhere.
Dwight
there was a few different things i was going to do in the rear for light...but then my buddy gave me an extra oem hardtop interior light.
so i wanted to make it work
it will be semi permanent...I am running OEM soft top bows
I like number one better it looks more balanced. I know the bottom of the light has two fixed nuts. If you removed those and made the top part of the bracket thicker you could tap a couple of holes part way thru then install short bolts from the top. A lot of work but don't you teach shop:hhmm:
Paint the bolts white on A, and call it a day :hillbilly:
Reason 1) I am the King of Indecisiveness :D
Reason 2) I was going to make another for Chris...but...thought maybe this would be better...or mabe this for me...and something for chris...
I just don't know (see reason #1) :hhmm:
No. 2 if there's sufficient clearance between backside and softop.
Personally, I would mount an led unit there.
Problem is with Johnny's bow over the door is it doesn't come apart to install the two bolts into the light housing. Are yours stock bows across the top of the door? All the set I have that is a one piece not a two piece part.:hhmm:
X2
I saw yours Dusty66 ...kinda didnt want to drill thru the door bow however...the main reason for doing it this way to start.
Dusty66 .... does it get hot on the reverse side of the light? I knotice that yours is close to the canvas...as my second one is as well
My bows are two piece Pakistani Bows I did drill through the top piece only and used the OEM windshield wire clips to hold the wire in place.
You Da Man:grinpimp:
X2
No I nevere noticed It getting hot on the canvas and It is not that close to the canvas about 1-1/2" I also have a second Dome light mounted on the roll bar that has Its own power source and is much brighter.
