Interior Bed Liner?
Coeur d'Alene, ID
So I'll probably be throwing some bed liner on the inside of my rig as soon as I get the whole thing sandblasted and cleaned up. I've seen one pig in the past that had the bed liner done on the inside and I've seen a couple with it done on the outside. I figure getting the inside done and maybe getting some drain holes would make it nice and easy to maintain and off road in. I'm thinking bed liner with some floor mats placed on top of it that can be easily pulled out? Has anybody put bed liner in their pig? Which brand did you use? Do you like it?
Thanks! :)
Jacob
I used raptor liner on my 40 and coated the under side if my pig. I'll probably do my interior also. Goes on real easy from a self contained kit.
Frank,
I did use the Lizard Skin products, but they were for noise and heat reduction. The bedliner I used is Monstaliner. There are some good threads up in the paint forum.
The Lizard Skin is a much softer product and not made for use as a bedliner, that's why I sprayed the Monstaliner over it. You can spray or roll it on.
