Interest in Custom Rear Cargo Storage
Yeah, for sure. Funny you say that. I almost did just that but I through my audio ideas out for more storage. If you can picture this I see the two big boxes about 6-8" shorter. The front most storage can be shrunk in half width wise but this would also add the 6-8"" to length (front to back) The other section could fit a 8" or 10" in a bandpass type box. Would be a fun project.....
What are the 2 skinny hinged wings that run the outside length of cargo area? I know to cover wheel well but the is still room that a sub as well as an amp should work great. Any thoughts
There isn't enough room in that area for a sub. could possibly fit a small amp in one side.
Update: I just had a chance to build another set for a mud member. This one is wrapped on taupe/tan carpet with black hardware. I will be installing it Mon. Pics to follow.
Looks nice
...via IH8MUD app
Looks nice
...via IH8MUD app
Thanks! I have some sets cut ready to be assembled. PM me if your interested
Finished up another set of box's for a mud member. I installed them this evening. I used a taupe color carpet with black hardware. It matched very well. Here are a few pics:
Did you ever come up with a design to incorporate a sub ?
...via IH8MUD app
No. I will only come up with a design if someone is interested in purchasing. This would also require a deposit. Thanks for you interest
These draws look very nice. Have you had a chance to build up a set for a 60 series?
Total finish weight?
How about using Baltic Birch in varying thicknesses as appropriate to cut weight like the Drifta set ups?
^^^I haven't done a 60. I would offer discount for the first proto . Weighs approx 80 lbs. I wouldn't use diff thickness masterial. The savings wouldn't be worth the strength imo.
Thanks. Would you need the vehicle to pattern off of? Perhaps just for the wings? How long do you think?
I plan to build around a 50L NL fridge mounted to the floor, so a 2/3's unit rather than full across. Still trying to decide which side and whether to remove the rear seat.
Yeah I would need a vehicle to pattern. I know of one local member who just bought a 60. I think I can convince him. I was thinking it would be possible to put a spot for a fridge in place on one of the drawers. This would put it on the floor with anchor points on the main box. I can build it to your needs also.
Just started a storage unit for 4th gen 4runners. Should be done tomorrow except paddle latches ( need to order) and carpet. I did this last min as I had a couple days to spare.
Finished up the 4th gen 4runner storage
Well I'm here to revive an old thread. Scrowley are you still making these? I'll send you a PM as well.
I can still make units. I have 1 4th gen 4runner box built ready to go.
Did you ever make one for a 60?
