Gents:
Been a while since my last confession here. In the meantime, my neato whiz bang aircraft temp and pressure guages have been spitting numbers in the cockpit for the last 8k miles or so. Here's some of my observations regarding intake air temps.
GIVENS
TFZJ80 - Stock intake location and hardware
Davtron dual temp guage (+ differential) installed - 1 probe at the inlet of the airbox, the other probe in the intake manifold
Sea Level +/- 300feet
OBSERVATIONS
Normal cruise - intake air settles at approx +8-10f over ambient temp
Crossover speed to temp drop is 30mph. Speeds over 30mph, the faster the temp drops to 8-10f over ambient
Massive heat soak up to +50f over ambient during extended stops (stop lights in gear). Noticeable climb in temps on a fully warmed truck at ~45seconds stopped (in gear)
Normal Cruise delta-T = On SC truck, the manifold temp is almost exactly 60F over inlet air temp. Spikes higher with extended SC loads, but always comes back to rest at 60f Differential.
Goofy anomoly?: First 30second of startup - temperature differential is -2f (read SC outlet is less than intake air inlet)
CONCLUSIONS
A lot of stop and go and/or offroad at low speeds could give *temp* benefit to an external inlet air source. For highway speeds, the benefit to inlet temps is negligible or less.
NEXT STEPS
For me anyhow, I'd like to seal off the high pressure zone in the fender to see if it's possible to isolate the engine bay heat from entering the inlet cavity in the fender. Blocking off the rear fender opening and sealing the fender at the airbox inlet should allow the fender to be an ambient temp/pressure zone.
HTH
Scott J
94 FZJ80 Supercharged
Chicago IL
GIVENS
OBSERVATIONS
CONCLUSIONS
NEXT STEPS
HTH
Scott J
Chicago IL
