Maybe use anti seize when putting back together..
Probably not as exciting for all of you, but considering this is my first time working on a truck I'm pretty excited - got everything apart last night after about 3 hrs (and a sick pack) - didn't run into any big issues - took my time taking notes and labeling things. From the looks of the gasket, this thing was leaking like a sieve - is that a fair assumption based on pic? Will call a few local places Monday to get the surfaces milled, order up some new gaskets, and hope to get it back together next weekend -
Thanks for the replies all - a few pics below
Awesome thanks! There was a vacuum line running from the manifold that was plugged with a nail - that must be it - great infoThe brass tube at the top of the carb that is facing forward and has nothing connected to it is the power valve vacuum line. It needs to be connected to manifold vacuum or the stock VSV or else it will run very rich and get bad gas mileage.
Great advice, thanks!Just remember if you bring it to a machine shop go have it trued up make sure it's done with the intake and exhaust manifold bolted together. Looking good .I bought new studs and brass bolt and used antisize when I did mine
