Intake/Exhaust Manifold Compatibility??
Tampa
New to me '76 has a nasty exhaust leak at the head/manifold interface. Turns out the intake is of a '76 vintage and the exhaust manifold is a 3 piece design from a '79+. Is this okay?? The manifolds don't match up exactly, i.e. not on the same plane - so I plan on having the suface milled true in an effort to help it seal correctly. Am I on the right track here - or will I have more problems with this? Should I look for an exhaust manifold of the correct vintage?? Thanks.
All of the '75+ 2F manifolds should work with each other. As you have found out, they should be planed together to assure a good seal with the head.
Hawk - you're right abou the "mostly" part. The upper bolt holes match fine - the lowers are a little off - but the ports themselves appear to match up when using the gasket as a template. In an attempt to get the best fit - I bolted it up to the head and then tightened the bolts joining the two manifolds - it's still off, but not as much. I'll get it milled and hope for the best. Thanks.
Started putting THAT carb back together today.;) One of THE most f-ed up carbs I've seen in a long while. Large checkball in the bottom of the accel pump chamber, small one in the discharge side. Accel pump pivot bolt flared to the point that it almost completely bound up the pump arm. Serious corrosion and oxidation in the fuel bowl and in the venturis themselves.
A couple of internal parts are even swapped in from other years!:eek:
Not to worry. It's all going back together pretty nicely.:)
How much did they charge for the resurfacing?
Even better question, would they be interested in doing a job like that AGAIN?
LOL - glad it's in capable hands. Now you see what I dealing with on the rest of the truck - its coming together nicely though.
NAPA charged $79 including tax, shop fee's, etc. They stated they had to "take off a lot of material" and proceeded to show me the clogged belt on the sander to prove it. Looks like they took off between 1/16th - 1/8th of an inch total.
What gasket are you going to use for reinstallation of the manifolds? For what it's worth. I have used the Man-A-Fre kevlar one and it burned up in less than a year. I then went to a factory replacement and have had no trouble since.
