Instrument Cluster Lights
Fort Collins, Colorado
Hi all! I apologize if this has been answered, but I could not find it: my instrument cluster lights are not coming on when I turn the lights on, and the cluster dimmer spins all the way around with a click in the middle. Any ideas as to why this is? Thanks!
Dimmer spin is normal. Mine does the same and still functions normally. As far as the cluster lights go... Have you tried checking the fuse box? Might be as simple as that.
Good to know. I looked at my fuse and it is still okay. The lights came back on again tonight, I guess I will look through my wiring at some point and see if I can find a loose connection.
Did the lights come on again after you pulled and replaced the fuse? If so, it could have been just a loose connection.
I went through this same thing with mine. It ended up being a bad rheostat there is a write up some where here about how to jump it so the lights will work. The only thing is they are at full brightness when on but it doesn't bother me.
Thanks! I think I will tackle that this weekend.
...Not on mine, I've got a fixed amount of rotations
I should have clarified... The dimmer spin is normal in the same way that a cracked AC switch bezel is normal. However, it doesn't impact the functionality of the dimmer dial (at least in mine).
