I installed new u-joints in my front DS tonight using a vice. Install went really smoothly but I may or may not have a problem. One of the joints seems a little stiff moving in one plane. I greased it to see if it would loosen up and it didn't. Also, grease doesn't come out of one of the cups. Problem or not?
Used to have a transmission shop so over the years installed hundreds of U-joints.
After you push the cups into the flange and install the clips it is good idea to tap the the joint back from each side so the cup is tight against the clips. You do this by supporting the flange and driveshaft cup holders on the two open jaws ( 3.5" to 4" vice opening)of a vice and hold the driveshaft by hand and tap the other cup holder down into the clip by hitting the flange and cup ears on the driveshaft or flange.Repeat for all four cups and that will seat the cups against the clips. Usually don't have to tap too hard, one good tap usually does it. They are usually tight because you slightly over press the cups into the cup pocket and compressing the seals a bit where they fit in the cross.
Having the grease not come out evenly is not a problem it will probably correct it self after you drive it a bit.
Thanks y'all! I tapped it a few times. It moves more freely but not as smooth as the other 'plane' but I'm sure it'll loosen up more after driven. My main concern was the rubber 'seal' on that particular cup seems inferior, or a lot less rubber, than the other cups AND no grease came out. I'll go ahead & install it but keep an eye on it. I was amazed @ how easy these u-joints were to install. I'll post back here if it gives me problems or fails too soon. Thanks again!
I just put in a new spider on the rear u-joint on my rear drive shaft last week. Parts also from Toyota. I thought I got it on straight, but apparently didn't, and one of the needle bearings came loose and was at the bottom of the cup (my fault). It had the same motion symptom you are describing (stiff movement), even backing both cups out so the snap rings were solid against the u-joint; though I hadn't tried to add grease to it before taking it back apart.
I did find out, after taking it back off, that the needle bearing, when being lodged sideways and being pressed on, damaged the plastic ring inside the bottom of the cup, which holds all the bearings in place. I ended up using a new cup from the extra spider set I'd bought (to eventually put in the front u-joint on the rear drive shaft). It was definitely the problem, and now operates exactly as it should.
I'd say if you suspect this might have happened, it might be worth redoing--for peace of mind, if for nothing else.
It appears this was a problem, I think. Today I was greasing my u-joints, which I do every oil change (~5-7K miles). This u-joint slides back and forth. Hard to explain but I can slide the d-shaft about 1/4" side to side at this joint. It's like the joint is sliding in the cups. This IS a problem, correct?
1/4" side play is way too much. Check to see if either bearing cup is sticking out of the yoke more than the others. I would guess that you have some noise/vibration when driving?
If you can see movement other than the bearings rotating in a u joint assembly something is wrong and it needs to be rectified, 1/4 movement is really bad and I wouldn't drive it at all.
After I greased it & the d-shaft slip joint, it made the 'thump' mostly go away. It also made it where I can now only move it ~1/8". From the get-go I had a feeling this u-joint was messed up as soon as I installed it (notice I started this thread in 2014 when I installed it). When I installed it & noticed these issues in the OP, I inquired about the issue w/the vendor on here I bought it from but he said it was fine. Well, it wasn't fine. These OEM u-joints, when they are fine, don't fail in < 2 years/25K miles. Oh well, lesson learned. I'll replace it ASAP. Thanks for yall's input!
IH8Mudders, need some knowledge here. My '95 LC (1 FZ-FE) has some slight vibration when I left off the gas on the highway. Also, when I let off the gas it slows down pretty quickly, it just doesn't want to coast. The feeling is a little bit like driving in 4th gear on a manual trans car and you let off the gas and it slows down pretty quickly. I think this is a U Joint issue. The rig has 176k and I would bet the previous owner was not as meticulous as I try to be with maintenance and upkeep.
If it is U joints that need to be replaced, can anyone recommend a manufacturer for the parts?
