Installed 1" wheel spacers
Long Beach, CA
I put on some 1" wheel spacers today after work. I went with spacers because I wanted to widen the stance of my 80 but I didn't have the money different wheels right now. Eventually I'd like to get some gloss black steel wheels for my 80 but for now it will be spacers. I know not everyone likes spacers but I've ran them on my pervious 80 with no problems along with having them on my Jeep ZJ and almost all of the different BMW's I've had. I found this set of 4 on Amazon for $80 with free same day delivery. The build and packaging on these is very nice and they came with the needed hardware. I haven't been on the freeway yet but on the expressway home at 45mph everything was fine. The downside to 1" spacers is a small amount of the stock wheel studs stick out past the end of the spacer so depending on what kind of wheels you have this could be a problem. The stock wheels have cut-outs on the back side of the wheel so this isn't an issue for me.
Now for pictures.
full
full
Here you can see the small amount of stud that sticks out past the spacer can be seen here, its about even with the 16 etched on the spacer.
full
Final look.
full
Thanks for the share.
As you probly know put some blue locktite on those & re torque them like in 75 miles.
I would never use any kind of thread locker on lugs. The leading failure is improper torque, close second is debris between mounting surface. Anytime wheel type is changed, the hub mounting face should be cleaned to bare metal. The contact surface differs between a wheel and spacer, so the debris, rust, paint, etc, that has formed with the wheels, will hold the spacer off of the hub. Debris doesn't make a good foundation, with driving forces, can allow movement, the fastener tension can be lost without the nuts moving. Nuts being glued on reduces or destroys the effectiveness of the torque recheck.
The proper method; clean all debris, paint, rust, etc, from the mating surfaces, torque the spacer nuts to 100ft/lb, install, torque the wheel to the appropriate torque for the nuts/wheels. Drive a few miles and recheck wheel torque. After a hundred miles or so, pull the wheels and recheck spacer torque, they shouldn't significantly move.
If it has hub-centric, washer type wheels, the lugs will not center the wheel, will have runout, feels like imbalance. Get 3 acorn/taper type lugs, install them on every other lug, tighten (maybe 40-50ft/lb) this will center the wheel, then install normal lugs on the other studs, torque to spec, now replace the acorn nuts with normal. If running this setup, carry the 3 acorn nuts, need to be used every time a wheel is mounted.
We have seen a couple of spacers where the studs were not fully pressed, bottomed in the holes, so the wheel lugs had to pull them in, causing quick, few miles, loss of fastener tension. We now put all spacers in the press and confirm that the studs are solid. But rechecking them several times, after short (10-20mi.) drives will do the same thing.
It's pretty simple, the key to having solid mounting is clean metal to metal surfaces and proper torque. Has been well proven, in what ~100yrs of auto tech that it works, done correctly glue isn't needed. If you screw it up, the wheel is likely to come off and glue isn't likely to help?:hillbilly:
The spacers give a nice stance to it. Looks great
Thanks, I'm happy with the final look. I'm hoping in a year or two to be able to afford gears and 35's, maybe 37's, to get look and capability I want from my 80. I'm hoping next week to finally have time to do my sleeping platform with storage drawers.
And like Tools said loctite on wheel studs is not a good idea for this sort of application. A couple double checks of the spacer to hub torque after the initial install is all that is really needed then just double check them when doing work anytime the wheels are off.
My rig had these spacers with 315s on factory rims. Worked great, looked nice. Had to pull them off when I went to 37s. Never had a wheel stud or spacer stud get loose by following Tools' recommendations.
