If you think your stuffing new window channels in from the top you've been fooled.
Remove the door panel and glass to do this job quickly and right.
I paid $60 each with free shipping for the Front Runs
- Lower Window and Peel Door Runs Out. Pull up where they run down into door.
- 3 Philips Screws (2 Under Armrest, 1 Under Handle) 1 Philips Screw in Door Opener Handle.
- Pry Door Lock/Window Switch from the side closest to Door Hinge. Unhook connector.
- Pry door all around on edge to pop clips loose.
- Unhook bottom courtesy Light.
- Lift Up to release inside door panel and set aside.
- Using loose Razor Blade Cut Rubber Sealant on Plastic film so film comes loose.
- Hook back up Window Switch and run Window up slightly from bottom till both 10MM bolts appear in opening door frame.
- Remove bolts carefully to keep from dropping them in bottom of door. Then work window out carefully (Two Hands). Easiest if you remove runs when window was down 1st.
- First side will take about 30 mins next side about 10.
