Inspection, please
Northern CA
My new baby, 94 LC has a problem with steering, specifically when I turn the steering wheel to the left. It feels like something is hitting or skipping every time I make a left turn. Turning right, on the other hand, is smooth as it should be. Since joining this great website, I did some investigation and took some pictures of a few things I was concerned about.
1) PHH. It looks good.
2) DS Right Axle
PS Left Axle
Transmission oil leak?
So, with these pictures and the information above, please, help me with what I should do. Thanks.
Long side front axle tube seal is leaking.
-B-
-B-
Is that the front axle on the DS or PS from the pix above? So this leak causes the steering wheel to skip while turning left? If you don't mind, let me ask you about fixing such a leak. Thanks, B
The long side axle is on the left (driver side on US spec vehicles.) The leak lets diff oil get into the steering knuckle which washes out the moly grease. Severe cases will result in failure of the birfield joint. I don't know what you mean by the steering wheel skipping but typical symptoms are clicking while turning and severe symptoms will result in a "popping" noise.
To fix this will require a front axle service or what we commonly call a birfield repack. Some call this (incorrectly) an axle rebuild.
-B-
-B-
So, the driver's side front axle should look like the passenger's side front axle, almost covered in that greenish grease (from pix above).
As for the symptoms, you're right. It's clicking while turning left. So I need a driver's side birfield repack. Now, let me ask you. I have never done any work under the hood of any car other than checking the oil. I don't have any tools, yet, but I do have a 94 FSM and this website as a guide. Is this something I can do? Would it take me a whole weekend?
to me, the PS looks worse. Soup is runnier...
moot point, you should do both at the same time
(where are you?)
There is a comprehensive write-up on the front axle service in the FAQ. I strongly recommend that you do both sides at the same time as this is a 60k service and it is very likely that the other side needs to be serviced.
The front axle service is not technically difficult but you need some basic tools to do the job. I believe there is a complete list in the FAQ. If you have no tools then you can buy them with the money that you will save by doing this yourself. Typical shop rates would cost about $1,200 for this job.
Plan the job first. Get all the parts & supplies during the week. Start on Friday after work and get everything ready for Saturday morning. Jack up the truck, put jack stands under the front axle, and remove the wheels. Get a good night sleep and start early on Saturday morning. Complete one side (in your case I would do the right side) and you will know if you are missing anything on Saturday which will give you time to get to the Toyota dealer or parts house before they close on Saturday. Finish the right side on Saturday if you can or early on Sunday. If you don't dally too much with the cleaning and chasing cone washers around the garage, you can finish up the left side on Sunday afternoon and take it for a test drive.
If you are a "while you are in there" type then this would be a good time to replace the rotors and/or front pads if they need it. As part of the job you will repack the wheel bearings (30k service item). Consider replacing the lower knuckle studs and nuts. At a minimum, remove (double nut method), clean the threads and use Blue Loc-tite on installation. Torque ~50# on the studs.
The key to doing this the first time on a Sat/Sun is preparation. Get everything ready to go on Friday evening. Read the FAQ section at least 2 times. Print the relevant pages. It helps to have all the torque specs printed out and handy when you start the assembly process. You will need a big box of shop towels, tools, drop light, jack stands, trash bag, 8-10 cans of brake cleaner, 8 tubes of moly grease, 2 tubes of wheel bearing grease, knuckle bearings, axle service kit from Cruiserdan, and the list goes on.
-B-
(where are you?)
Eric is correct. I misread your first post. The leaking seal is the one with the pictures of the "wet" grease. I edited my post.
Did you clean off the lower nuts on the left side lower control arm? They look too clean to me. Any records from the PO?
-B-
(where are you?)
I am in Rocklin, CA
-B-
So the passenger side front axle with all that greenish grease is the one leaking.
No. I did not clean anything and I don't have records from the PO. Since this picture is from the driver's side which is also the better of the 2 axles, maybe, the PO serviced this side.
I am in Rocklin, CA
your "DS right axle" made it sound like a RHD :)
and yes, your "PS" is like the US PS side with the 2 rods attached. (Is it the other way around for a RHD?)
Sorry for the confusion. Here's the picture of the PS front axle which really needs repair and I should fix first. Right? I'll take your advice and do both of them.
yes, the PS one looks worse IMO. What I meant is that the grease looks much runnier (wet) than the other side so that likely means that the seal on the PS side is in worse shape than the other side, leaving oil to reach the knuckle in larger amounts.
You could certainly do only 1 side if time is of the essence. But it's much more efficient to do both as you need all the same prep, tools, you'll need to gather cleaning containers which will be a mess, you will have grease everywhere which you will have to clean off the walls, you'll likely want to drain the oil etc. Plus you'll have to make it up seriously to the :princess: after you put the Birfs in the dishwasher and who wants to do that twice...:eek:?
:D
Thanks, e9999 and the rest of you Cruiserheads.
you should do both at the same time.
How about the other picture where there's an reddish oil leak. Is it a transmission oil leak? Solution?
Yes, you should repack both left and right sides when you do the job. Someone has cleaned the lower steer arm and those studs and bolts that attach it to the lower portion of the steering knuckle. It is possible that side was done recently but it is good practice to do both at the same time and since you have clicking birfs you simply MUST do both at the same time.
-B-
I wonder if the PO just cleaned up the knuckles b/c they were greasy - both of them look cleaner than they should with that thin of a mix, especially the backing plates under the balls.
I would also not assume that the PHH "looks good" just by looking at the exterior. assuming it is original and has 182K miles I would plan on replacing it.
