My 97 developed an occasional severe shake in the steering wheel. Pulled the outer front wheel bearing and it was eaten...as in, some of the rollers were missing or disintegrated. Put a new race and outer wheel bearing in and put it back together.
The occasional shimmy was still there. I pulled the entire hub, and the inner wheel bearing (on the back of the hub) has about 1/4" or so of play in it...it will move in and out. Is this normal, and it gets seated in the race when you put the hub on the spindle?
If the inner bearing is seated when you put the hub on the spindle, my guess is that I did not get the rotor/hub all the way on the spindle. Or, is there something that is supposed to be between the oil seal and inner bearing?
