Injector Replacement - Anything else??
Orange County California
Looking to replace my Injectors on my 3FE. Is there anything else I should check/replace while getting this done? I have had the rig for 7 years and not sure what has been service or replaced in this area (Injectors, Throttle Body..etc).
As much as you can 😂
Vacuum hoses, water lines, cables, spring loaded connectors, heat wrap on wires all that little stuff is tedious but worth it.
Use electrical contact cleaner on plug ends/ connectors, then a dab of dielectric grease.
Someone else can chime in on mechanical/ sensors to check whilst in there...
More time under the hood in the driveway or garage means less time under the hood out on the trail/ road!
Anybody think Porting and Polishing the Intake would be worth the time and money??
