INITIAL REPAIRS - SURPRISE!
virginia
One week of new to me ownership and this is what I’ve replaced, and now the check engine, VSC TRAC and VSC OFF lights are on, but I believe it related to the catalytic converter. I coded for this when the lights came on prior and were cleared. What could go wrong? Still love it.
  • Oil change
  • Air filter
  • Heater T’s
  • Timing belt & water pump kit
  • Tensioners
  • Pulleys
  • Serpentine
  • Fan clutch
  • Fan pulley bracket
  • Fan bracket bearing
  • Power steering pump & resevoir
  • Starter
  • Secdry Air Injection Pump
  • Secdry Air Injection Valve
  • Manifold gaskets
  • Air Driver Assy.
  • Air Injection Valve Assy.
  • Front wheel bearings
  • Front CV trans axles
  • Brake fluid flush
Loose or failing gasket on fuel cap gives the christmas lights as well. Start with that.
