Independence Day Maintenance
Spring Lake, MI
I am sure I am not the only one here thats going to take advantage of the weekend. As for myself, Ill be changing the fluids of course, but I have a question.
What might be the source of what I guess would be an incessant squeaking noise that seems to becomes more prominent the longer I drive?
Ive looked using the Search for anything and everything relating the the idler pulley and the whole shebang that goes with it. I found a lot of info about the pulley going bad so I think I may have found the source. I just wanted some up-to-date info to see if I need to look at anything else. Thanks in advance for the feedback.:cheers:
Nobody, huh?
I recently replaced all the belts for the second time, with OEM, and replaced both idler pulleys.
The engine sounded a lot better at idle. Now you can hear the valves tapping instead of that light squeaking from the pulley. ;)
more description is needed.
Is the AC on when it squeaks.
Does it do it ad idle, if so can you help pinpoint the location
Does it change with speed, what is the effect on the squeak when brake?
Belts squeak but you should be able to hear that at park to if you have someone rev the engine.
Need to figure out if it is movement related or engine related (park with engine rev)
I finally solved my engine bay mystery squeak with some WD-40 on the upper shock mounts.
It does it when the A/C is both on and off, so Im thinking its not related to that since it doesnt really seem to get worse or better when the A/C is on. It does not seem to be respective of engine speed either. It does it at idle, and Ive tried to pinpoint the location, but its hard with all of the engine noise. Seems to be near the bottom though and not the top.
I still have a decent list of unfinished items from the last 3 day weekend that I posted up here.
Suffice to say, the front passenger seat has still not been reinstalled!
:bang::clap:
I'll reply later with an updated list.
Cheers!
:bang::clap:
Cheers!
Do so in another thread. He is asking for help with his problem.
I would drop the skid plate. 4 bolts and tighten the ac belt as it spins even when the AC is off. That should take about 5 minutes and give you a good data point.
You provided good data points.
I wouldn't do this as a fix but to isolate the problem you might spray belt dressing on your belts one at a time to see if you can isolate it to a single belt, assuming they are tight.
