Ikamper RTT on kickstarter
I dont have a ikamper dealio, but I have the shadow awn. Here is a look at the alucab frontrunner brackets.
These are mounted on my home made rack. Obviously they will not work on the prinsu, but you can easily just use a section of thick wall square tubing to bolt onto the sides of the vertical side rails. The inner box on the shadow awn has a bunch of predrilled holes, just line it up and mount it. It will feel more sturdy if you add a mount right at the rear hinge area for when it is open.
I would say 1"x 4" maybe 3/16" wall tubing would work. Maybe a couple of 6 inch spans to spread the weight.
You live in Colorado. Im jealous!!!
Come on out! There is always room for more.
Those are some seriously beefy mounting points... Holy cow. Are they specific to your rack?
Those are specifically made for Frontrunner slimline racks. But they worked with my home brew rack since I used 1x2 aluminum extrusions, similar to the front runner setup.
**edit**
I measured the awning for you. The half bolted to the rack is actually a aluminum box, so it is solid enough to redrill holes of you need to, but it comes with a bunch predrilled already, and you just poke through the cover for the holes you actually use for bolts.
ZeGerman & CRZR45
I just got a Prinsu on my 200 to swap my Ikamper over to it from my 100. How did you go about mounting the Ikamper extrusions to the sLine 1X2 of the Prinsu together? I was looking at these.
I agree on everything here. I love the Line-X you had done to the shell too! So rad. A foxwing or Alucab would work fine and combined with the iKamper awning you have all sides covered with shade. Here is the hinge side open for clearance reference. View attachment 1613003I have an Eezi Awn that fits fine. Worse case is you offset the tent on the rack a couple inches.View attachment 1613006
Is that the batwing or manta awning? And clearance wise the hunger doesn’t affect anything. I got a Ikamper 2.0 on my alu cab explorer canopy and I wanna run a 270 awning on driver side.
I have the Eezi Awn Swift. I actually now work at Rhino Adventure Gear in California and sell iKampers. I’ve done many iKamper installs with Batwing awnings. You can definitely run a 270 awning with the AluCab canopy. Rhino Rack makes a large variety of beefy awning brackets that mate with most 270s that will mount to the AluCab crossbars and get the awning in the correct position with the iKamper.
I assume the HD awning brackets they make for the batwing is the one your are talking about?
If you were going to mount the tent to the roof rack and then mount them both onto the roof as one unit they would be great. Otherwise trying to get those Tnuts to line up,,, thats gonna be a bitch.
ZeGerman & CRZR45
