I have set the vales on 22RE's before and didn't like it, all the stuff you have to remove...
...REinstall...
....if its wrong...do it all over again....
Can one of the last things on the stand be to get a hot gun and blast the top end get it to swell and then set the valves?
Never heard of anyone doing this before...
See anything right off I don't?
What do you think?
Another one:
I have several and will probably have more 1st gen wiring harnesses
the PITA ones that are held on with wire clips NOT the simple press and pull types...
Can I get a professional to cut my wiring harness in half, get some sort of plug in board and install?
I have always been under the assumption that it could possibly cause a short/ surge? (any breaks in the harness)
I will not attempt it.
Would painless have something like that?
What do you think?
Another one:
If you do that, there should be no problem with current fluctuation.
