here is the video. It’s a Toughdog install not BP-51. 2:00 minute mark is ware he starts talking about welding 10 mm nuts to the valves.
When you finally get that bolt loose, we should set up a common time for everyone following to have a Mud toast with the good stuff.No, they were not high quality bits. Two Craftsman brand and two Crescent brand.
I'll add, once you get it loose, when you reassemble it coat everything with marine grease. I live in Chicago but I've not had any more rust on mine since I did that after the first winter here. BTW I tightened all the way, then backed it off half a turn or so, put the grease on, and then re-tightened, so I could make sure there was a small amount of grease around the lip of the screws.When you finally get that bolt loose, we should set up a common time for everyone following to have a Mud toast with the good stuff.
It's all fixed. Cheers to you all!When you finally get that bolt loose, we should set up a common time for everyone following to have a Mud toast with the good stuff.
Yes, it is completely level now.Did that sort out the remaining lean?
