ignitor, ballast resistor?
No ballast resistor was for the points to kept them from burning up or over arching. At least that is what I thought
If the Fireball ignition requires 12v constant power then no I would not run the ballast resistor
If the fireball system came with a dedicated 12v coil it won.t need a ballast. The old original coils will get hot running at 12v
The main reason for the ballast system is to allow full 12v to the coil when cranking to help starting. Once running, the coil receives about 8v due to the resistor.
In reality when cranking, the voltage drops quite a bit unless you have an enormous battery , so the coil only receives about 8-10v even without a ballast.
