Ignition Wires
Memphis, TN
Hi All,
I did search the board for experiences with different brand wires, but I didn't get any hits. Look at all these wire brands http://tinyurl.com/y8o3zesPrices range from $57 to over $100. As I'm not the most proactive mechanic, I would want the best performance (longevity & conductivity). Does anyone have a preference.
Thanks,
Natdad
Most on here will agree that OEM is best. In my experience, I've noticed the OE wires fit better under the plastic valve cover trim.
OEM all the way! Look at it this way, my '97 still has the original wires and still runs great with 140k on them. Factory wires have the prod date on them so you always know what you've got
I still plan to replace my wires as part of PM procedure but they'll be OEM for sure knowing I'll get at least 100k out of them.
My wires just got replaced with OEM. They had 150,000 miles on them over 18 years and there was nothing wrong with them. I'd say that's pretty good performance and longevity.
x4 on OEM. Just replaced my wires that have 150k miles on them. Still in spec as per the FSM. Not planning on replacing the :princess: for quite some time. ;)
Thanks for the recs. I have always gone with OEM, but wondered if there was any experience otherwise. I am replacing my wires much sooner than everyone else. Even though I am not a very proactive mechanic. About 10 years ago, I installed a high energy Jacobs ignition that is a little hard on the stock wires. I also would gap my plugs to 0.075". It sure does burn up the plugs as well. Typically, I have replaced the plugs every year and wires, cap and rotor every two years. One time I had switched to the Jacobs wires and the ignition burned up about an inch of the coil wire, but the engine still ran with the spark jumping accross the inch of ash that was once a wire. That Jacobs Ignition with the "Lifetime Guarantee" has failed and I have switched back to stock. Jacobs itself seems to have imploded as there is no long a website.
Natdad
.075"?? Isn't stock .8mm (.032")? My numbers may be off, I'm going from memory having replaced the plugs last week. It's just that more than twice the gap seems like a lot to me. Also seems like the heat range would be different as well.
I assume you are seeing a benefit from this ?
what are spark plug wires?
hahahahahaha
I would take Autolite plugs and increase the gap from 0.032 to 0.075". The high energy ignition added about 15 hp. I advanced the timing to about 13° BTDC and that added about another 5 hp. I didn't dyno it, but I did take it to a dragstrip and calculated the hp increase on the improved 1/4 mile E.T. I just took my timing light to the track and kept increasing the advance by 2° until it stopped getting quicker times.
Among the problems I mentioned above, this requried higher octane fuel, which obviously costs more, but also has less energy so my mileage suffered a little bit (~ 0.5 - 1 mpg).
I also agree with the substandard quality of Jacobs, especially the wires, that's why I switched back to stock. The only reason I used Jacobs was MSD didn't have a Toyota sysem. I think the coil is ok and alot of people have used them. The issue lately has been the controller failed. This is when I looked on the internet to find Jacobs has imploded. So I will just take the whole system out.
Natdad
That's pretty impressive gains. Would've loved to see an 80 motoring down the strip . . .
What was the time, 18 seconds maybe?
With the full set up, I was getting 17.65 sec. I made some other changes (ECU and high flow cats). The ignition was the only thing that gave more power. Land Cruisers are really easy to drag race. As soon as I staged (I would also shallow stage) I would stomp on the brake. When the first yellow would light I would floor the gas. Then when the last yellow (before the green) I would let my foot off the brake. I would always get consistant reaction times.
One time I beat a Viper to the 1/8 mile. It was some kid that sold his soul to get a Viper. He botched the launch and then missed the 1 - 2 shift. Vipers are really hard to drag race, I never see them at the track anymore.
