Stupid person needs help
Grants Pass, OR
OK - so I'm trying to get my spark plugs out - here is how far I've gotten. What do I just yank on the wire (just seems like a bad idea)
Your lead is broken.
That rubber unit you are holding onto is part of the piece that is still in the hole, with a twist and a pull the whole thing should come off the spark plug.
My guess is the boot section has become glued/gumed to the wall of the tube down near the spark plug. You might be able to get pliers on that to get it out but that plastic/bakelite breaks easy (as you have found out)
A little WD40 down the side of the boot before you try the twist and pull might help break the bond with the boot and tube.
wait till you get to #6 ;) you are going to have some fun!
Those are aftermarket plug wires. After you get them off I suggest you replace them with a set of factory wires, 90919-21557.
What Dan said....the OEM leads are sooooo nice.
They also come with all the harness clips that you apear to be missing.
I just had them replaced about 12,000 miles ago - The mechanic said these were the correct wires (Bosch premium something) Did I get taken?
In my opinion, yes.
2x. The OEM ones were still nice after 120,000+ miles on both of my trucks. They both got new ones when I did the HG on them.
/Mild hijack/
Hey Dan, are you still collecting the HGs? I still have my 2 hanging on the wall.
Wow, This was from a reputable shop in Minneapolis that specializes in Toyota. They have been Angie's List award winners numerous times. I wish I had the patience, tools, and know how to do things myself (patience being my #1 enemy)
My 92 still has the original plug wires on it and they work fine.
The cap and rotor and plugs are new.
I will be replacing my wires with factory here in a couple of weeks when I make a large part order from Cdan.
/Mild hijack/
I have a nice collection and unless they are something other than the expected #6 fire ring I do not need them.
Both scrubbed at #6. Caught early - one was actively leaking the other wasn't as obvious. Into the barrel they go.
You can have my old set of spark plugs I took off my truck. About 150k on them. Worked fine when I pulled them off, replaced as PM, but in excellent shape.
Fri or Sat I'm free....
I wouldn't fault a shop for using non-OEM parts, especially a quality brand like Bosch. They have to cut costs wherever possible.
I also wouldn't put too much credibility in awards- it just means the shop has good people skills. :D
I have a tool that is specificly designed to get at something just like that. It's basically a long needle nose pliers but with a round end that allows you to reach down and pull on those wires. I'm sure you can find these at many auto parts stores.
Have to ask...Why are you replacing your spark plugs if the wires were "just" replaced 12K miles ago? Did they not install new plugs at the same time?
My thought...Since you are now looking at having to replace the wires anyway (at least that one) they grab as low as you can and pull and hope it comes off whole, or at least enough so you can get the spark plug socket in there.
Edit: I like Brian's tool idea better than my grab and yank...
You can replace the wires and plugs yourself...Doesn't take much in the way of tools and the OEM tool bag that is hopefully in the back has just what you need, especially to get to the PITA #6. And this is coming from a guy that considers himself a 1 :banana: :wrench: at best :hillbilly:
He's not replacing them, but checking for fouling.
This wont help you but I will chime in and say I just finished changing the plugs wires rotor and cap. Original wires had 156,000 miles on them and the plugs rotor and cap only had 100,000 on them. I had no issues with the oem plugs breaking although I did twist and wiggle and gently "break the seal" before yanking them.
Oh dude, my experience with Bosch left me feeling that they were anything BUT quality. I'll NEVER recommend them to anyone. For what it's worth, I like my NGK wire sets.
The last I knew, plugs for a non-supercharged truck are under $2 each from Cruiserdan. His plug wires actually wind up being less expensive than Magnacore or the like.
So... You're replacing plug wires. If one boot did that to me, I'd want them all out before another one can do it.
You'll have the plugs out. Pulling them out, inspecting and putting them back in is about an hour process. New set is ~$12. If your time is worth less than $12 per hour, let me know. My lawn needs mowing.
If you're looking for fowling to determine if you need a head gasket, start with #6 - that seems to be where it happens 90% of the time or more.
IMHO YMMV - I am not a mechanic.
