Ignition, tumbler issues causing starting problems?????
Kansas
Website
www.fj40dash.com
Curious if anyone has ever come across this or not. If so how did you fix it.....or did you?
I'll begin by saying that I've searched and searched, think I have it figured out, try that solution, starting gremlin seems to disappear only to show back up again. Think it was one problem, then another but seem to still have a starting gremlin.
I always get lights on in the dash, but sometimes the starter will not turn over. Took out the alarm system under the driver's seat via the connection in the kick panel on drivers side. Thought I had it fixed......Until it showed back up again!!!
At one time, It became so frequent that I ran a wire from the starter up into the engine compartment by the battery. When this elusive gremlin shows up, I leave the key on, pop the hood, pull cap off wire and touch positive side of battery. Starts every time. Then became so infrequent when it happened to me the other day, I forgot I had put the wire in there a couple of years ago. I know that sounds stupid but I don't drive the 80 daily, the 40 is the DD.
Leads me to believe I may have something going on in the ignition? Tumblers not quite resetting, getting stuck or not aligning with the key to send current to starter? I've never tore apart the ignition, I guess it could be a bad connection on the backside. Sometimes I can hold the key at start and maybe 5 to 10 seconds later it will start. Sometimes this won't work. I have poured Kroil into the ignition and it seemed to fix it only to find a couple of days later it wouldn't start.
I've changed out EFI relay, fuse, it seemed to fix it at first, then it showed up again and will disappear for weeks at a time.
By the Way, I mentioned above that I disconnected the alarm from under the seat, however I ran a shopping cart into the back of the 80 and the alarm went off????? Had to disconnect the battery to get it to shut off. Evidently I only disconnected part of the system. I would love to be enlightened on that one.
I would be happy to hear everyone's thoughts.
Here's another thought. From personal experience on one of my FJ40s, there's a spring loaded babbitt pin at the bottom of the lock cylinder which activates the switch. Babbitt is softer than the key, and if a key wears a cup in the pin it won't make the switch. This will cause an intermittent fault. This can also happen if a new key isn't cut correctly (maybe try all your keys?).
If this is the case you have two choices: buy a new ignition lock, or have a new key cut. The new key blank should be about 1/16" "into" the clamp. Tell the locksmith what you're doing and that you want the new key a little longer. If he's worth anything he'll know what you're asking for. (Note: a dealer will not be able to do this properly; they're not locksmiths)
I've never had this happen on one of my 80s, and it only happened on one of my FJ40s, but it's a cheap test. Thanks to the unremembered locksmith who gave this one to me.
Malleus,
Thanks, this makes sense, never thought about the length.
Scratching my head here trying to remember, but I believe the keys I carry for both of my 80's I had cut at the dealership, due to the fact that all the copies from PO's would work in the ignition but not in the doors. On more than one occasion I have been called due to one of my kids locking their fob in the 80. Plenty of spare keys, just nothing would unlock the door, and of course we had made copies of the copies!!!
Anybody know anything about the alarm system? I did the disconnect on the kick panel, is there another part of the system? The shopping cart into the back of the 80 and the alarm going off surprised me. I notice when I start, lock or unlock the red security light does not flash.
fj, sounds like you have a replacement lock somewhere (ignition is my bet) if your keys don't fit both locks.
There is a factory alarm connector under the driver's seat, but offhand I can't remember which years. My '94 has a factory alarm, my '95 doesn't. I'll look when I get home to check the harnesses there and drop you a line later.
I might be way off in left field, but perhaps it's the fusible link causing gremlins. It's cheap insurance to swap in a new one and keep the old one in your spares bin if it doesn't solve the problem.
Malleus,
I probably didn't explain that well above. Presently the keys I carry that I had made at the dealership will unlock the doors and start the car. Previously all of our copies were evidently copies of copies probably of a worn out key. They would work in the ignition but not in the door locks.
Became very frustrating after my beloved daughters would lock an 80 with the fob inside!!! It helps that I had a buddy who has a tow service. I became pretty good and getting the door wedged open to retrieve a fob!
Finally, went to the dealership and had new keys cut. They work in the ignition and the doors. A couple of Years later, the kids are out of the house I have no idea where the fobs are but I got back both 80's!!!
Dogfish,
I too thought it might be a fusible link, discounted it because I always had lights. But now that I'm typing this response I could see that it potentially could be. You're right cheap insurance to change it out.
Anybody got any wisdom/insight on the bumping of the shopping cart into the back of the 80 and the alarm going off when it's "supposedly" disconnected?
Malleus,
Dogfish,
I don't have any personal experience with the problems your 80 is having, but I have read a few threads where the fusible link has created wierd issues so that's why it came to mind. Probably wishful thinking, but it would be nice to have something fix easy for once, right?
I think the lock theory has led you down the wrong path. Sound like the very common symptoms of the very common "needs new contacts in the solenoid." And changing the fusible links won't hurt.
Some thoughts that might be useful. It's not always the cranky solenoid or just the cranky solenoid. This may not fix it all, but may improve it: Some Thoughts on Starting System Failure: Ignition Switch & Solenoid
Note that a new switch isn't necessarily a fix, but you can take the old one apart and clean, assuming you can get it back together. That might verify that circuit is good.
Or a loose nut between the steering wheel and the seat...
I have a similar issues on a 97 but basically the alarm is gone 'wonky' and it won't start. I did the starter wire trick as well. Once I took out the alarm system it starts each time. So somewhere in the wiring system had gone wonky. I've managed to get a 2nd (from another 80) alarm system and putting that in didn't solve the issue.
So looks like somewhere my wiring has a loose/brown connection (when the alarm(s) is connected) but ok when alarm is out (of the system)
When my runner would start and not start I did lot , short story replace the big main gauge wires to starter and that fixed it, old wires had corrosion in them not allowing power thru at certain times , replace those
SO THIS SORRY NO GOOD GREMLIN SUCKER STARTED DOING IT AGAIN.
I've went almost a year and had no problems until recently.
No start. For the past week, if I want to drive the 80 every time I have to pop the hood and use the solenoid jumper wire straight to the battery to get it started. To top it off, blew the head gasket in the 40 last week? That's another story.
Started thinking about NSS. Somewhere I read about what lights should be on in the dash when the NSS is operable......Too late I tore into it.
The connections on the firewall above the starter for the NSS. I thought maybe the PHH leaked onto the connections and that was the problem. Tore out starter took all 4 connections apart (Why I'm in there) and cleaned. Slapped some dielectric grease on the connectors and put back together. BTW antifreeze did come out of the plugs when I pulled them apart but the connectors did not seem corroded.
No Start. I can use my jumper wire that is tied directly into the the starter solenoid (3" upstream of solenoid) slap it to the + terminal and it starts every time.
So I jumper the BW wire to the BR at the connection discussed above, female side upstream of the NSS. No dice. Take a voltage reading on the BW wire & get 10.3 v??? Thought there should have been 12. Maybe there's only 12 when the start switch is on.
So am I losing voltage upstream of the NSS and don't have a full 12v to make starter solenoid close??? Or is it downstream?
Only splice upstream is I18 which I believe is behind the glove box. Only connector upstream is IH1 which I believe is behind the glove box.
There is a splice E& downstream of the NSS.
To check downstream of the NSS I need to have someone start the ignition while I check voltage at the solenoid to see if it's dropping below the 10.3 I measured at the firewall connection.
My thoughts are I got something going on upstream of the firewall connection because I should have 12 volts shouldn't I????
Anybody else have a problem like this???? I've read all kinds of NSS, connector corrosion, broken wire at NSS threads but maybe I've overlooked something.
Any ones thoughts ideas or suggestions is appreciated.
FIXED IT.
Well went around it. Got tired of :bang: . After the trouble shooting above, I believe the problem is more than likely in the ignition switch.
$10, 20 amp switch from Oreilly's. Assumed solenoid amperage was approximately 8 to 10 amps. I'm back to driving it daily until I get the 40 back up and running:clap::clap:
Didn't realize how dirty the 80 was until I look at this picture!!!
