Stock 1996 fzj80.
To start, I was having issues with a sparatic miss showing up. I have changed my spark plugs within that last 5000 miles So I was going to change Distributor cap & rotor button, but the parts store did not have a dist cap, so I get only a rotor button.
I get home & replace rotor button. The cap has some corrosion on the terminals where the rotor button passes. I clean the corrosion. Replace the distributor cap, and crank the engine. Immediately idle goes to 2600 RPM and stays there. I have tried replacing the old rotor button, and retarding the timing, but nothing works still extremely high idle.
It is late and I am not thinking clearly. What am I missing? Planning on going duck hunting in the morning, bit can't if I don't get this cleared up.
Any help would be much appreciated!
Thanks,
Mack
Thanks,
Mack
