I have a 71 FJ 40 and the engine will only shut off if I take the key from the run pos and turn it all the way to the far left ACC pos then back to center to remove the key. I just replaced the switch and the new one is the exact same way. does anybody know if I have it wired up wrong? there are only 4 spades on the back of it. Thanks for the help in advance.
The BR (Black/Red stripe) should splice into a WL (white/blue stripe). I believe it should be a 10 gauge wire. That WL runs between your ammeter and alternator B. It should be hot at all times.
The WL (white/blue stripe) that provides juice to the BR (black/red stripe) recieves juice from the other ammeter wire which is a W (white). Make sure you have a sacraficial "fusible link" on the W (white) wire where it attaches in the alternator lug. It stacks on the alt lug with the big battery + wire.
