Ignition switch position label/sticker?
Northern NJ
Question for the seasoned vets here... I have a 1970 fj40 with the ignition key switch on the dash. Did it come from Toyota with some type of ignition switch position label as shown in the pic below (not mine, just one I found online)? If so, is anybody making them or are they still available?
Thanks!
There was a small window of time in the early ‘90s when Toyota offered the replacement switch with that tag. I had 3 or 4 of them pass through my hands, never thought much about it. Then they were gone.
But I can confirm it is genuine.
i can 2nd mark A , for sure :
i had a 1965 USA spec FJ40L in my shop for several months , not only did it have that exact LASER / engraved / etched Key Position indicator
instructions TAB or plate on it .
it had a Common TR-33 Key same key as a 1973-1990 FJ40, FJ55, FJ60, FJ62
it was a original TEq Key with the code stamped on the shaft of the key itself,. key looked brand new !
- I can take 1 hard look at that OEM TEq key blank and Say it 100% authentic
- its called a Butterfly Key , due to its SUPER wide top u twist with you fingers
- it is VERY Ornate in nature , may have been like a Annerviersty edition
key perhaps ?
- will see if i have a image , but thats so freaking rare , see one ....
_ take note; How the position indicator , the then positions make a more modern range of motion, get me photz of old clutch in mission
- you tun counter clockwise , click with for brief break ...........
- Key code ID and info sheet ......sheet you will need it ...
Funny story about those butterfly keys. That’s what I run on my ‘68. The clearance between the HUGE key and my rollcage wasn’t great when I installed it, and I knew that.
we went four wheeling a couple of weeks later and while rock crawling through a creek bed, my truck shut off! I went to restart it and found there wasn’t enough room to rotate the key, as the cage was flexed. A buddy had to come over and hang off the side of the truck from the rollcage to get me the clearance!
there is the 1965 one too bad i did not take ant front side shots the entire
project ......... 😆
this the only living example image i have ever seen regarding the butterfly
key blank .
however , i believe Diahtsu or HINO still use it , but with there logo on
it of course .........
yep in 2020 ,🦋 keys still a south east asia Bling thing ..........
Now , if i can only ever find one NOS ..............🤔
and here we are :
TOYOTA's Child company is Retro-Loyal !
Diahatsu factory keys 2007 model year
also owned by TOYOTA
My March 1970 FJ40 was almost three years old when I got it.
Other than gun racks mounted on the sides above the jump seats it was unmolested and there was no label on the ig switch.
I have had the switch out many times and rebuilt it three times in the 45+ years I have had the rig so it is pretty much a no brainer what position the switch is in.
thats a PO HIGH Crime !
Marv picked up a parts cruiser one time that had the rotation of all 8 wheel cylinders scribed into the driver’s door! :eek:
Here is my butterfly
