Ignition Problems!! HELP!!!
The West
I recently installed a pertronix on my 1970 fj40 with a 3f and i am very frustraited. I am trying to save money by doing this mys elf but when something goes wrong i have no one to get help from ( without paying money) My dad knows nothing about autos, my friends think they know but end up messing things up even worse. I really need help here. Who all has had this set up. I NEED YOUR HELP. I am 19 years old . My name is Rachel ( just in case you were wondering) I am young and learning ...........and i need this help. thanx
If you really have an EFI 3F, the pertronix may not work with the ECU (Engine control unit) as the signals may be incompatible.
It would be helpful if you told us what you have done, what parts you are using for a coil and ignitor and what the symptoms are (eg. there was no spark when you checked this)
I have a niece named Rachel who is half Okie who lives in N Cal, but she is 21.
The pertronix is a common upgrade to older Land Cruiser F and 2F engines. Numerous people on this list have successfully installed it and are very satisfied with it, including me. To get started provide us with the following:
Make and model of Land Cruiser?
Which engine, if it really is a 3F, are you sure?
What made you decide to switch to the pertronix?
How did you hook up the pertronixs, including which coil you are using.
What are/is the problem you are having now?
The more information you provide, the easy the answers will be.
Their are lots of very good mechanics on this list that know quite a great deal about Toyota Land Crusiers, Pin-Head, being one of them. An answer will be forthcoming when you provide the proper details of you problem.
well it was a typo i have a 2f . Yeah and im going to be 20 in july
anyway i hooked it up correctly i guess i didnt adjust the timing on it yet. Where is the timing and how do you adjust it? i have a 2f
and a nother question that is kindof off topic. If I have a 2f for what year brake master cylinder do i need? how do i figure that out? thanx guys.
I'm 42, twice your neices age......i could travel to N. Cal? :flipoff2:
Just a thought since you offered. :D
Hi Okie,
Ive got this settup, Pertronix in a 2F, on my rig. It's usually pretty simple, but there are ways to mess it up. Did you, for example, remove the distributor from the engine when you installed the ignitor? Are you still using the stock balast resistor?
What symptoms does your engine exhibit when you try to start it?
The timing is adjusted at the distributor, it's sorta the "relationship" between the flywheel and the distributor. What coil are you using?
I noticed the pertronix rotor thingy is somewhat difficult to snap down onto the distributor all the way. When I installed one I didn't push it down all the way cause I didn't want to break it.
If you had the distributor out to install the Pertronix, you need to be very careful about reinstalling the distributor so that the end of the shaft is driving the oil pump. If the distributor isn't seated all the way in, then no oil pressure and your engine will sieze.
Start simple and work up.
1. Verify that there is a spark at the coil high voltage wire when you crank the engine.
2. If so, then check that all the spark plug wires are in the correct order.
3. To time it start by static timing it. Turn the engine until it is at top dead center on cylinder #1. There is a pointer on the bellhousing and a line on the flywheel that indicate TDC. You have to open the little window above the starter. The line and pointer line up at TDC of both #1 and #4, so you have to figure out which. If you didn't remove the distributor, just pop off the cap and look at the rotor. For #1, it should be pointing to approx the #4 spark plug on the block. If you removed the distributor, then remove the #1 spark plug, put your thumb over the hole and turn the engine until you feel pressure on #1. Then it is at TDC when the line lines up with the pointer. Once it is lined up at TDC for #1, then loosen the clamp holding the distributor, Rotate the distributor CCW about 10 degres, turn the key on and then slowly rotate the distributor CW until you get a spark out of the center wire.
4. This should be good enough for it to start and run. Start it, check to make sure that it develops oil pressure. If no oil pressure shut it off right away. Put a timing light on #1 and rotate the distributor until the pointer lines up with the little BB (not the line) on the flywheel.
Will you marry me!!!? Oh wait, way off topic, the whole girl with an FJ40 thing made me off balance, or was it totally attracted to you... I don't know but good luck with the Cruiser...
<-----------------Note to self "Don't flirt in forums"!!!!
