Ignition Kit
Las Cruces, N.M.
Anyone ever seen such a thing in their LC?
Label says:
ArcherKit Deluxe Capacitive Discharge Ignition Kit
Radio Shack, Fort Worth, Texas
It's wired in parallel with the stock semi-electronic ignition module. Any thoughts? Should it stay or go?
Truck runs ok. Does backfire on occasion and sometimes studders on a hill. Other than that, not bad.
Wow! That's an old Radio Shack kit made back in the late 70's to mid 80's. Personally I would pull it out and replace it with a working Toyota unit and keep it in the truck as a trail spare.
The original kit was made here in Colorado, then RS bought them out; I put one on my old Pontiac in 1966. It was a life saver for that old straight 8 engine. If it still works, I'd keep it as a back up. The newer Jacob's are, of course, much better units - but are still based on that old unit.
Will it hurt?
Will one of those new type of ignition boxes (msd, jacobs, etc.) hurt the point setup?
If I understand correctly, the points are only used for signaling and the ignition box delivers the 20-40Kv to the plugs. Is this right? Maybe I'm answering my own question...
You can use the points to trigger the Jacob's unit. I've been running a Mallory type points distributor system for over 10 years that way. Keep in mind that plugs gapped at 40/1000 will only last about 18K miles. Points will last for almost forever.
It is not likely that both the Radio Shack box and the stock ignitor are driving the coil, even if they are wired in parallel. Chances are that one is non-functional. The ignitor or Radio Shack box is basically an electronic relay that switches the coil on and off to make a spark. Because the ignitor does the high current switching, the current at the points is only a few milliamps, so the points have no arcing wear.
Thanks everybody! I will disconnect the RS box tomorrow morning and see if the Toyota box will fire. If not, I will be looking for a 76 igniter that piggybacks on the stock coil.
