Ignition Igniter wiring question. Installing Holley Sniper
npulver
Metal Messager
Ok, so the 1977 FJ40 im currently installing the Holley Sniper system on has an FJ60 engine (was told its a 87?). Following the Holley wiring, i was under the assumption that i needed to go directly to the coil with my rpm pickup wire, due to me not having a CD box, or an hei distributor. Upon hooking it up, i have connection to everything i need except an rpm signal (which allows it to fire the injectors). I currently am setup with my rpm signal wire (yellow in this case) directly to my coil negative post. No RPM signal while cranking. So my question is to those that know wiring better than i. What wire should i be hooking into. I tried to find a correct wiring diagram in the FSM that i have (has multiple years (FJ55, FJ40, FJ45 ect.) and the igniter wiring colors do not match up with what im showing in the FSM? Anyone have a clue?
picture of my igniter coil setup currently.
To clear up something quick. currently i can see that.
RED - to the distributor
White - to the distributor
yellow - cut off at edge of picture
brown - have to double check
Blue\Black (cant tell) - have to double check
Another thing to add, the vehicle DID run before swapping the holley over. just very poorly due to the carburetor setup that was on it.
After a second round of searching for what im looking for (naturally while im NOT working on the vehicle. i found my answer.
This website has a pretty good breakdown of swapping in a FJ60 Distributor.
Black​
To Coil -​
B​
Yellow​
Tach Connection​
EXT​
Brown​
To Coil + (and +12V)​
C​
Red​
To Dizzy Pickup + Wire​
White​
To Dizzy Pickup - Wire​
exactly what i was looking for.
You have the FJ60 igniter, -> click here <- and go to page 50 for the wiring diagram.
Partial wiring diagram for the '77 FJ40
