Ignition Help.
Long Island, NY
78 FJ40 - Over the last month or so, always cranked and started with little effort.
Cranking this morning, it immediately stopped cranking.
Batter good, I can hit the starter with 12V, it cranks...but turning the key, seatbelt buzzer nothing, brake indicator, nothing, and no 12V to the starter when cranking position or run position.
When I supply the starter with 12V and it is cranking and the key is in the run position, I get no spark either.
Bad ignition switch? Any other tests?
Thank you
Most likely a bad switch. The brass contacts do wear out over time. Mine went out years ago but my result was much worse. I couldn't get the starter to shut off. Battery terminals began melting and I had to use a hammer to pop off the negative side. New switch was only about $20 and was pretty easy to replace. Good luck!
Fuse
Ground
Connections
Switch
Good news is electrical problems are quick and easy to fix :D
Bad news is that finding the problem is often a nightmare.
It was 100% the ignition switch. I took it apart, cleaned the contacts and then hit them with 1000 grit sandpaper. I then re-greased with electrical grease.. Bam, fired right up and idled. If others have this problem in the future and search for starter issues.
Check list:
Battery voltage
Starter main wire voltage
turn key to start, starter ign wire getting power
hot wire starter
check for spark while hot wiring starter
hot wire wl and by (run circuit) at ignition switch
hot wire starter (should start/run)
thanks
