Ignition coil question
Byhalia, MS
I have reassembled my fj80 and prior to dissasembly it ran.
I have no spark now and the lead to the coil has 12v.
The manual says to test the oms resistance between positive and neg terminals. When i do it reads .40 or so for a spit second and then drops to 0.0
I have tested several times and the manual calls for .36 - .55....does this mean it should read this constantly?
Maybe plugging in and disconnecting a few times has been all the coil could stand?
Am i testing it incorrectly?
Any help is appreciated...
93, fj80 with the standard 4.5l
The truck had a low idle and when i pulled the throttle body off it was pretty gummed up.
I also pulled the intakes and cleaned them due to lots of oil and carbon buildup.
Since i had them off i replaced plugs, wires, cap and rotor and injectors.
Figured ot was a good time to do a complete tune up..
The coil by the way tests continuity between positive and negative terminals. I doubt this is a good thing.
Measuring resistance in the 0.36 - 0.55 ohm range is not easy even with a QUALITY meter and having zeroed for test lead resistance. If you don't know how to accurately measure low resistance values you will be getting meaningless results that will lead you to believe you have a problem when you don't...
You hopefully had ignition power turned off while taking your measurement. What kind of meter are you using, test lead quality, did you zero the 'offset'??
cheers,
george.
I agree with George. Low resistance readings are tricky at the best of times.
Have you gone through basic "no start" troubleshooting? There is a comprehensive FAQ and troubleshooting section in this forum.
Emergency Troubleshooting Procedures - FAQ Item (Recommend Keeping Copy in Truck)
Is your CHECK ENGINE light illuminated with the key in the ON position before you crank the starter?
My check engine light is not on but the lead going to the coil has 12volts and there is no spark coming out of the coil. Guess i can go get a new coil and see if it does the trick easy enough.
If your CEL is not on you are not following the Troubleshooting procedures jonheld provided check your EFI relay, Fuse, and Fusible Links without those working properly the ECU will not send signal to the coil
When the key is turned to run, motor off, the CEL should be on. If not there are likely other problems, most often no power to the ECU, if so, there will be no spark. Coils almost never die, backup on the diagnosis, what works or not?
What do i check when there is no check engine light? The Haynes manual i have only states to check for spark and test coil and replace.
Ok, here is what I have tested and tried today.
I followed the emergency test forum and it appears all fuseable links are good. The AM2 link when disconnected and reconnected activated the efi relay and i hear air from the fuel pressure regulator.
Should i hear air from the fuel reg? The same goes for when i disconnect the MAF and reconnect. I am still not getting a CEL.
What am i missing? Is there a chance when fuel sprayed out of the laeky injector that it put a bunch of air in the system? I get fuel out of the fuel reg hose. I just havent tried checking it when cranking. Didnt want a big mess again. Maybe i need to to check if there is adequade fuel coming through.
How do i
How do i check power to the ECU?
Voltmeter, test light, etc, with the key to run do you have power at the B+ terminal, in the diagnosis box?
Yes, 12v present. Im beginning to wonder if my CEL is burned out. I think i remember seeing it on before. I did unplug the main wire harness to remove the intake manifold. Guess i have to get under the vehicle with the wife watching for the light on the dash. Just in case i have a bad connection.
cheers,
george.
The book said to pull power too but im not sure how that matters due to me bench testing the coil, lol.
Can you look further in this post? I am at my wits end with no CEL. Changed efi relay, fuse is good. Hear relays and activity when i pull the AM2 link and put back together.
I hear air hissing from the fuel pressure regulator...is this supposed to happen?
What should i do to correct if not?
I thought both of these leads were attached to the mount for the coil.
They are attached on the other end to a bracket on the engine and on the fender well.
Do they both go to the same place? Can you help me out?
Those are ground wires, connect to the frame at/near the coil.
