- Thread starter
- #61
Update... cables and tps ok, not the problem. I have a new, recommended mechanic on the case. Initially he cleaned the MAF, found it to be running well, no codes etc. and gave it back. It acted up again (idling low), I took it back, he then noticed that the ground terminal on the battery was very loose. It's been like this for some time, I just never realized it was a problem (the terminal was not able to be tightened down anymore). He explained that a host of problems can result from this and perhaps this is the problem. He put a new connector on (free of charge) and sent me on my way. Drove home, running great, in fact it felt even peppier, no problems, fingers crossed, feeling hopeful.
As if it could be that simple. This morning on the way to drop my daughter off at school, it begins stumbling at low speed, shaking, running rough, bogging down. Check engine light comes on (first time in this entire saga). Take it back to mechanic, hooks up to computer, reads cylinder 4 misfire. I take it home change spark plug #4 (it's very black). It continues misfiring on my way back to the mechanic. He pulls the plug, checks compression (175), checks spark.
He decides he needs to consult some sort of Toyota Mechanics Hotline that he has membership to, and do further investigation. He mentioned wanting to find out how the #4 fuel injector is behaving. He says he wants to rule out at least one other thing before thinking the problem lies with the computer. For some reason, he didn't want to share his speculation about what the other thing is. This has become quite the mystery. I'll post back when there is a change. I'm taking it back in next Monday.
Perk
Perk
