Idler Pulley
Al Ain, UAE
Connected to my trying to diagnose a metal rattling sound from the front of the engine (hoping it's not the timing chain, thread here) - the idler pulley caught my attention.
What exactly does it do?
First I thought the belts were on the wrong way, since they pass to the outside, and not around it, but the FSM diagram shows that's how it should be.
It acts as a belt tensioner. Others may chime in.
Bingo. It tensions the belt. You will know if it is failed/failing by loosening the belts and trying to turn it by hand. If it is resisting a turn at all it is seizing. I had mine freeze up and cause belt slip in a big way. I looked, saw burnt marks on the pulley, and the belts contact surface was polished.
Takes about 30 minutes to replace it. Remember to back out the bolts for the tensioner to almost completely out and it will go easier.
