idler pulley for water pump
I have a 81 fj40. The previous owner removed the smog devices including the air pump.
It was replaced with an idler pulley. The pulley is making a whining noise, verifyed by lubricating it with the whine dissapearing.
Do I just replace the pulley or is there a better solution.
Thanks
3 options.
1. Take it apart (duh) and inspect the bearing, replace or repack bearing if serviceable
2. Belt needs to be replaced/tensioned or both
3. Pulley out of alignment.
IF you sprayed the belt then you need a new belt and/or check alignment. You have a diy bracket, so you have to dig into it and do some good old-fashioned labor to figure out the root cause.
There are two aftermarket options, neither of which I really like, but they are 'better' than what you have currently.
TLC Performance
SOR/Man-a-fre
So... found a machinist who replaced the bearing in my water pump idler pulley. Replaced belts. All good runs great and Quiet!
However I noticed the idler pulley has an ever so slight wobble. Dont know if it did befor the bearing replacement or not. A problem?
