The FSM states 1.25 turns for the carb but I know that several folks have pointed out that it is more like 4.5. As well, where do you recommend idle speed setting for the initial setting?
OK, and here's probably the dumbest question. I did not replace my insulator gaskets AND there was not a plenum gasket on the carb when I took it off. The 40 idled great prior to the rebuild.
Is it recommended to ALWAYS replace the insulator/plenum gaskets? I assume the plenum was not done becasue you cannot buy it by itself. So, I am going to use the 2bbl insulator to body gasket and cut it so it is open instead of just two holes.
Thanks
Thanks
