idle pulley question
I run the Gates smooth belts (and hoses too). They are good and not too expensive. There are other manufacturers that make good stuff....Tire manufacturers and battery companies come to mind.
Sure, take off the part on the front of the engine that Toyota put there. Also, take off the hood insulation and in a few years complain about your broken belts and awful hood paint. Like doctors think the appendix is completely without function.
Overseas trucks didn’t come with hood insulation, regardless of engine type.
True, but most of them are less concerned about slightly more noise than Americans, value durability more than luxury.
And you absolutely can’t run 37’s or your wheels will fall off!!
here is my follow up to the idler pulley issue i was experiencing last month . I installed a new factory pulley a couple weeks ago , there is a distinct difference (noise) with the pulley installed . Im going to try and adjust the belt tension a bit , if the noise is still there . Then the pulley may be removed . This all started with an alternator & PS pump replacement , bc i thought the original noise which was quite loud was due to the alternator bearing's issue .
Marc
Marc
If you are using the cogged belts, you will have SIGNIFICANT noise. That's why everyone recommends using the Toyota Belts.
There are also some good aftermarket belts without the cogs on the inside. Some have cogs on the outside.
