I am playing the California Smog game and people tell me that the idle mixture has no effect what so ever on the mixture when it is not idiling. But I also have read that is does effect the mixture at higher RPM.
After thinking about it, it seems like the idle circuit is on all the time since after you let off the gas it idles. So it seems like it would effect the mixture. If you are running rich at idle and then dump more gas through the jets then you are still going to end up high or rich?
Am I right? Wanted to confirm this on here.
Sounds like I need to lean it way out for the test so it barely idles steady.
I set the idle using iDave's method I have read on here but with the air cleaner off and smog pump inlet off it is not the same as with the air cleaner. I am going to try and make some tool or adjust it with the air cleaner on. Anyone had luck doing this?
