I had the following numbers on a leak down test. I am guessing 55 psi is about nominal for a good cylinder?
82 FJ60 2f 130K
100 psi IN
1-37psi
2-20psi
3-28psi
4-20psi
5-27psi
6-55psi
The air was leaking through the hole at back of valve cover. This is crackcase or blowby pressure?
compression test
1-120
2-90
3-120
4-130
5-105
6-150
Time to rebuild?
What is good to clean up carbon buildup on rings?
82 FJ60 2f 130K
100 psi IN
1-37psi
2-20psi
3-28psi
4-20psi
5-27psi
6-55psi
compression test
1-120
2-90
3-120
4-130
5-105
6-150
Time to rebuild?
