Identify this noise
Dahlonega, GA
I had just got back from a 4 hour road trip and as soon as I turn into the parking lot of my dorm at Georgia Southern, my engine started to make this sound.
20151010_140411.mp4
All fluids are topped off, belts are fine. Can't see anything visual. I'm thinking it's inside the fan. What do yall think? Haven't found much on the search tool, but maybe I'm not looking hard enough.
Sounds like a bad bearing. With the engine off, take the belt off and spin the pulleys individually by hand and see if you hear it.
Ended up being my AC compressor. Just cut the belt and then it was gone. But with the compromise of no AC for now. Thanks for the input.
The compressor was just about shot anyways. I've had problems with it the past two years and it was no longer blowing cold or strong. Put a metal rod on the compressor as a "stethoscope" and felt the most resistance and grit with it than anything else.
Will double check this week on the idler pulley though. I've already replaced the bearing once after the pulley seized and fell off, hopefully it's that, but I may need a new compressor anyways.
