You're probably not going to find that in a catalog...I blew the hi pressure line off today. Anyone know what model I can order?
Also it blew when I installed a new steering box (85 monte carlo) could this new steering box not like the pressure?
Lots of shops can make that hose. I use the Parker store. Take the old hose in with you, tell them how long you want it to be, wait 15 minutes. Cheaper and quicker than ordering one.
Edit: The more I look at it, the more that connector looks like a simple compression fitting. If so, probably not DOT approved, perhaps why it blew off. A good hose shop will install the correct (safer) fittings.
You are right, it is copper!
The hose blew off where it connects to the line. He used compression fittings for the connection.View attachment 2149227
when you remove the nut what does it look like? Possible missing a ferrule? or maybe suppose a flare on the end of the tube?
It's not copper, it's the reflection off the paint.
John, looks like there is a shiny section of the tube, the last 1/4", it might have been a ferrel. doesn't really matter, other than wondering why, as copper is not made for those preasures. the OP just needs to get a hydraulic hose made with the correct fittings.
