ID cylinder head
I'm trying to figure out the manufacture date of a cylinder head I picked up years ago. Thought it was from a 72 or 73. But doesn't have ports for the air rail, so not a 73. I show 9/69-3/72 would be 11101-60072 with a 11101-60073 as a sub. Show 4/72-9/72 being 11101-60074 with 11101-60076 as a sub. This head has 60032 cast in it. I have the valve cover and rocker assembly with it. Valve cover is steel with a oil fill on top. It has the bosses where the ports for the air rail would be tapped,
Anyone know what date 60032 is? @65swb45 ?
I have no reason to think it was not a US import. Probably over twenty years ago when I got it. Was off a cruiser in my old neighborhood. Think the engine had spun a bearing and engine was pulled and laying in pieces. He gave me the head and oil pan if I remember. He didn't mention it being a non US import which were rarer twenty years ago.
Those r the only cast numbers?
I thought there was cast date numbers as well on the heads
Should be on same side as the 60032
Think this a date code but not sure how to read it. Possibly 9/70 with a serial # of 0519?
Also have this head that has this casting. By a early aluminum valve cover.
Which not sure what it off of or even when I got it.
61080 head looks like it has an allen plug in the air rail port?
11101-61080 appears to be a 3FE head out of a FJ62 and FJ80.
Years ago I bought a two tubs full of FJ62 parts. Very possible the head was included. Sold it cheap because he just wanted it gone. Probably had the head and just had me take it. :meh:
Is there another number in the front side as well? A single number?
On the front side by the thermostat housing? That might be a challenge to see. The head is over six foot up on pallet shelving. Thermostat housing still on and on the back side. I was a lot younger when I put it up and and had room in front shelving.
This head was cast on 10-03-1973. The “1003” is October 3rd. The larger “3” circled on the left is for 1973.
From your pictures, it looks like yours was cast on May 19, 19xx—you just need to find that last single number for the year.
Hope this helps.
if it isn't cracked, it's worth a few bucks.
Between the second and third head bolt hole on the top intake side
At least I think it’s right there.... or between the 1st and second
Hope this helps.
Thank you both, looks like it was cast May 19th 1972.
I have never had it checked but everything else in the tubs were in good shape. Some even had printed labels on them. Doubt he would have kept it if was cracked.
