Icon 2.5 RR Install Help
San Diego, Discovered by The Germans in 1904
My Icon 2.5 RR shocks arrived today so I’m stoked. The fronts are normal but I ordered the CDCV option for the rear for adjustability. I plan on installing this weekend but have just a few questions.
The fronts came with brackets, bushings, hose clamps, etc. They also came with step by step install instructions. The rears came with all necessary items as well, but no instructions. Mostly looking for where and how to install what I believe is the RR bracket for the rears. Anyone have experience with this?
While unpacking I noticed the protective shipping boot thing for the rear RR’s had pink oil stains. I assume this is from the shocks. Should I be concerned about this or is this normal? Any help is appreciated.
Pretty stoked.
This is the oil I noticed on the reservoirs for the rears. Should I be concerned? I cleaned them off and they don't seem to be leaking but they are not being compressed or anything.
Here is what I think are the brackets for the rears. Anyone know where/how this mounts? The Icon website says no instructions available for the rears.
They resevior mounts mount to the frame rails, on the outside. There is a short tab that goes in the rail connected to the bolt. I called icon about another issue, they were helpful.
I would take a Pic, but mine are mounted to the sliders now.
The rear lines running to the reservoir are JUST long enough to reach the above mentioned frame rail mount location. I say this because it feels like there’s enough tension on the line to give you pause. It’s normal. Also confirmed with Icon. The line will also likely touch the rear sway bar end link. Icon makes a little plastic “hose guard” for this. I think they’re like $12 or something. Worth it as mine did show wear before I installed the guards. Pics above are how mine are mounted.
