I thought 33's cleared stock?
Tempe, Arizona
I picked up tires last week and had them mounted. They are 285/75-16's and measure exactly 33" when on the truck and at 35psi. I'm completely stock other than a Slee transfer plate at the moment with OME Heavies being ordered this week (if I can afford it :o)...
What is with these not clearing? They rub the front fenders if I hit a very large bump on the street as I've yet to have a chance to test them offroad. Is my s*** just worn out too much or are most 285's not measuring a full 33"?
I come up with 35.5" from the ground to front fenders in the front and 36.5" in the rear. I'll keep tire choice to myself until someone realizes what they are and I get tar'd, feather'd, and run out. :flipoff2:
My 305/70/16's (33's) rub too. Not much, just when backing up and the wheel is cranked a bit. Just enough to scare bystanders. No biggie. A new front bumper will fix that. The stock front bumper mount is bent inward slightly thus the rubbing.
I'm talking fenders though, not the front bumper. This is the second stock front bumper I've killed - and I was really trying to being nice to this one. :mad: Note to self - remove before leaving the street.
Retreads huh? :D
-Spike
Retreads huh? :D
-Spike
:D I rather like them. They have a nice rumble below 35mph but they clear up fast and are SMOOTH as glass at 75. Rubber is nice and soft... I've heard good things about high-tec-retreads on Pirate and a few other places. We'll see how it works out - I've never seen another 80 with them. Can't beat $400 for five 33's.
There was the can of worms :flipoff2:
That was my next question- only saw 4 in the pic. Nothing wrong with trying something different, especially if it's cheap. Let us know how they do!
-Spike
i had the same size tire, but the bridgestone revos and i didnt rub at all. No matter what i did, couldnt make them rub. Guess each vehicle has its peculiar little quirks and all.
I am running 285's of the godyear MTR flavor currently on my 94, and I too can'tmake them rub. Mine is as stock as it comes, but not for long. I am looking into a 2.5" heavy and 305's. But currently I am pleasedwith the stock suspension and 285's. Maybe its a fluke?
Matt
Matt
What do they measure out to with a tape measure? These are true to size 33" tall all the way around with full weight and 35psi in them.
Shoot, I have the same tires. I had them on my old 4runner and they worked great, so I now have them on my 80. I think I have around 35k on them and they have a ridiculous amount of tread left. The ones on the 4runner didn't last nearly as long . . . not sure if Hi-Tech has changed the compound. I also siped the ones on my 80 with a box cutter, that may help the life. It has made them way, way better in the rain and snow for sure though.
Since I have J springs, I really can't help you out on the rubbing thing.
I've heard they moved over to a harder compound than prior, but I know nothing for fact. What are the details on you siping it with a box cutter? Sounds like very hard work :lol:
I had 285's with very worn stock suspension, no rubbing even with a full load of wood hanging out the back (1/3 cord of heavy Pinion).
The only thing that rubbed was the rear mud flaps when I hit a bump on pavement.
The trail I logged on was steep and full of runoff mounds so I had full articulation.
The trail was a fun bobsled run when it rained...wish I had a wood stove again.
... :flipoff2:
Most 285's don't measure 33", size depends on brand. Every brand of 285's that I have seen on a stock 80 setup have cleared. Retreads run slightly large, the tire carcass is shaved and new rubber is molded over it, making for a slightly larger tire.
There are a few things that can make tires rub;
Non stock backspacing, spacers or rim width. This tosses all of the stock tire fitting recommendations out of the window, yours look stock.
What tire carcass are yours made from, some brands of carcass are larger than others.
Are your stock bumpstops in place? If not the axle will over travel causing rub.
I installed Nitto 295's, (IIRC slightly over 33") on my bone stock rig and this is the only place where I could make them touch, not even enough to rub the paint off.
Do the retreads measure larger than a stock 285/75/16?
Where did you get them?
My 285's measure out at 32.25" at 28 psi. I can't imagine 3/4" more would rub on mine, but you never can tell.
These are Dueler AT carcasses. Stock bumpstops are in place.
Yes, by a fifth of an inch for the CALCULATED SIZE (32.8") that a 285/75/65 should be. As far as I've seen many run smaller than this in reality.
Mine rub right where the fender curls around to the inner fender well. I think that'd be enough on the right truck.
http://high-tec-retreading.com/DesktopDefault.aspx
And I thought my MTR's where 35" (305/75/16.) NOT, 33 1/2".
Dear god, I'd be somewhat pissed.
