I need Leaf Spring Bolts
Lake Tahoe
As with every other F-ing bolt on my rig, the bolt on my leaf spring pack snapped while taking them apart. I wanted to redrill the main leaf to flip the fronts and was going to clean up my 55 rears. So where in the heck do I get a leaf spring pack pin bolt? Or should I just plan on making one? Any suggestions?
If you mean the center pin, Napa carries a good selection. They are made by Rockford. The local Napa here has them in a big blue bin with a bunch of other bolts and stuff. You'll have to match the head size as close as possible. Cruiseroutfitters also has them, or did last time I was on the website.
I drilled my springs out a bit to run a larger diameter pin. Stock FJ40 pins in particular are pretty small. As long as the u-bolts are tight, you usually don't have any problems with the pins, but once the u-bolts get loose you can shear the spring pin. I've seen that a couple of times including once this year!
call your local toyota dealer and tell them you want to oreder them! the retard at the counter will tell you that it's not available correct him because I just ordered some from toyota 9$ each with the nut, witch is a seperate part #....ordered them like 3 days ago I know they have them so don't take sorry thats been dicontinued as an answer thats just there way of not looking and getting rid of you! don't waste your time fabricating one or hunting the local Napa or bolt shop because the ones they have aren't the perfect match I tried napa and a few other parts places and found close but no cigar matches trust me on this one by the time you pay for gas to drive around you could have paid the dealer for one and just wait 3 days to get it
