i have no lights
Big D
i can't figure this out. this is what is going on. i only have my instrument cluster, light, ignition cable and hazard lights connected. The truck runs and drives and the only lights i have are my brake lights. No turn signal, headlight, rear light side marker lights....nothing. I am completely at a loss. Alt is good, new battery...she starts without hesitation. where should i begin looking?
jason
I had the same problem. Bad ground. Run the ground wire down or provide a ground. Can't remember the ground wire color, white?
Ground wires are all over the place....usually white with the black stripe.
ok...i am a newb when it comes to the 40's but recently i replaced the wiring harness in my 40 casue the PO did a real hack job on the wiring. He desmogged the truck and i think he used it as a hunting truck or something but i don'th have any relays in the truck at all. i do however have a box full of stuff i got from him. where is the light relay located? this might explain why i have no lights anywhere....even on the dash the lights don't work. this is that last thing that is prevently me front driving this daily. Kinda hard to drive at night without lights.
Oh, so it's not like your lights were working and then they quit, you haven't finished wiring them up yet. Is that it?
I think you should look in the box that came with the rig. Then finish wiring it up. Then come back with a specific question.
jason
well my wiring is completed. my brake lights work when i push on the brake pedal but those are the only lights that work. i assume that i am missing some small part to this very large puzzle.
Well, if your brakelights are the only lights that work, then I don't think you're done wiring yet....
So, what kind of re-wire kit did you use? A stock loom? painless?
You are undoubtedly missing a piece of the puzzle, but at least you can see the picture on the box.... We don't even know what it looks like.
i used a stock wiring harness to replace the hack wiring harness the po had.
I had a simular problem in my 40. It turned out that the 5amp bus fuse in the oem switch couldn't take the load of my lighting system. Check the fuse in the switch. I had to change the switch to a 20amp switch to carry the load. When mine went out I was on the highway and with no moon to see by. I wnded up using my floods to get myself home. Took me forever to figure it out...good luck.
let me ask ya'll this...where do i plug those three wires into that come out of the headlight? I think this might be a key to my problem...i don't think i have that part.
If the individual headlights were not wired up it wouldn't open the whole circuit, just that individual light. To my knowledge each light is grounded. The three wires are lows, highs and ground.
Check the fuse in the switch. See if you have power in the switch. What size is the fuse in the main box? What size is the fuse in the switch? If it is a big amp fuse in the box and a smaller in the switch it could be fried. I compensated with a larger in the switch and the switch failed. If all your lights are not working there is a main componet that is bad. I would check those two first and work out from there.
I would check the fuse on the headlight switch. The OEM switch has a glass tube fuse on it that you'll have to peer under your dash to see.
headlight connector
http://globalsoftware-inc.com/coolerman/fj40/Page5AImages/P1110004.JPG
this is from coolermans sight--go there and have a look at the rest
his is a 71 but he also has a FSM with the schematic posted
Good Stuff
see the headlight connector?
sounds like you have a problem other than an individual connector though
Do you have/know how to use a multimeter? If not I'd verify all the wiring visually per the schematic
