I been a bad, bad boy........
Dallas, TX
Or: Why one should not ignore the "Oil Level Low" light.
Or: Didja even notice that the pig seems to run smoother after an oil change?
What I did: Changed the oil tonight, it was due, been about 7k miles, maybe a bit more, not sure. I gauge the need for a change by how many times I add after the previous change, so I had added four quarts since the last change, and seeing that I get about 1500 miles before it burns the top quart off, I had somewhere between 6k and 7.5k on the filter. Time for a change.
Did the change, started the fuzzy fellow up, let it run for about 30 seconds, shut it off, had another glass of bubbly, then checked the level. Perfect, which is good because when I buy the new oil, I but two 5-qt jugs and three quarts. Adding exactly four quarts out of a five quart jug is almost an art. When I run out of "spares", it's time for an oil change. Simple.
So about a week age, the low level light was coming on when the oil was still cold, first time I got up to cruise speed, then going back out when the oil warmed enough to drain back normally. Time for a change methinks. I buy the new stuff, then tonight I change the oil. Simple, what's the point you may ask if you're still reading. Well, what do you do with your used oil, other than weed control or save it for the space heater in the shop? You re-cycle, of course, exactly what I, as an environmentally conscious enthusiast, do. And how does one get one's oil to the recycle center? In the container which the new oil came in, of course. So myself goes to pour the old oil back into the one 5-qt container that's totally empty, and guess what? All my old oil barely filled the 5-qt container. Now being that those on this forum surely know exactly how much oil a fuzzy fellow should have in it at all times, and comparing that amount to what I recovered from my drain pan, and allowing for the smallish amount still in the filter (I use the LX filter), I was pretty seriously low on oil.
Point, and not the one on top of the hat I'll be wearing for a while: when that little orange Aladdin's lamp comes on, top it up.
I think I'll have some more bubbly now.
Didn't know there was a low oil level light... And I have a leak
Heh
So I musta had at least six quarts in it, not bad.
I don't have a "leak", unless you count the tail pipe.
Seriously, I can recall soccer moms and stockbrokers coming in and reaming our bores about two things on their LX450s: 1) "I had to put a quart of oil in this thing and you just changed it!" and 2) "what do you mean it needs brakes? It's not even a year old!"
I'm jaded.
If you don't see the oil level light come on when you're going down trails, you aren't wheeling hard enough
I've heard that running it on as little as 4-5 qts is no big deal seeing as how the oil pump pumps from the bottom of the pan. I do not subscribe to this line of thinking but it isn't the same as if you had a 5 qt capacity and were running on 1 qt.
Can anyone confirm this?
edit: When I say, "no big deal" I don't mean it is recommended, obviously, just not the end of the world.
Ed Zachary = Texican for : "exactly"
In all seriousness, it'll eat up the cam journals in the head. The oil level gets low enough and aerated oil is pumped through the engine, and by the time it gets up to the head, it's mostly air. It happened a lot in the last rear-drive 6-cyl Supra, so MrT figured an idiot light was a good idea. I agree.
