HZJ60 Build
MK VIII will move 4200-4500cfm depending on the year and you can get one at the wrecker. 3.8l Taurus fans are the fan of choice for off road rigs around here because they move 2500 cfm and cost $14.95 a the pick n pull.
I doubt the wreckers are selling many replacements. I'll bet most are going into projects. They are the hot ticket for hot rods, mustangs, and wheelers
Radd Cruisers,
Did you ever come up with a t'case disk parking brake? You talked about a while back.
I don't know what rad you ended up using, but I used the original 2H rad duw to time and money constraints, and ened up cutting and turning the bottom port outward to clear the fan. Then i made a shroud to slip in between just in case. An electric fan would be pretty baller though. I may go this route later in the game, i'd be curious to see what you come up with.
more pics
Overlord said:
Radd Cruisers,
I could not find a disc and caliper to work with, we ordered the tail shaft and brake mount from Steve MAF.
Biggest compaint with the disc was the very good possibility the output seal would leak eventually contaminating the brake pads.
I still would like to make one if I could come up with the parts.
Rob
Thats what I thought.........
Thanks
Rob; What's the voltage / model # of the cordless Hitachi drill sitting on the bumper? I'm in the market for a cordless, and have been looking at Milwaukee, Bosch, Makita, etc. Sounds like a great deal on the Hitachi.
14.4 volt, they are clearing last years model out for fancy looking new unit with the same features, different look is all.
All metal drive gears inside.
After a week of using it off and on its finally need a charge..........WOW..
HZJ60 Guy said:
Hey PW, did you see some of those flex-a-lites flow 5500cfm????
That's power baby...
Ding ding ding, a light went off today as I quickly remembered the truck is 24 volt system.
Does Flex a lites sell a 24 volt unit???
rob
Rob
So, you went with the drum style? I thought about that, but will the drum style work with early cruiser or mini/4runner CV/double cardan joint?
What about using the rotor and caliper from All Pro?
I might just try the All Pro.
Drum style should work fine with th e CV.
VTCruiser said:
What about installing a third battery for all 12v electronics? Run a converter to charge and a seperate fuse block.
Thats a whole other can of worms, my feeling is find a 24 volt fan, it would be superior IMO in the long run.
lowenbrau said:
They are out there. I trialed a 48V airconditioner for a telco cabinet and it had two 24V electric fans in series on the condenser. It was made in Holland though.
Only 24 volt fans I have found so far are in England.....
I believe the good gentleman promised some pictures? C'mon, Rob, my project is in the dark, I need to live vicariously through Tom's! :)
Chrome mirrors painted black, or OEM black mirrors?
search for 203 linkage....I posted some pics of my new linklage that I built for my 203 to split case....and sorry for the thread hijack...post some pics and Henry will leave happy :) :)
