Hydrogen CNG Power
North Front Range, CO
My fuel cost might be enough to convert to hydrogen or CNG.
Anyone do a conversion or know where I can get parts or kit to convert?
I did some searching for hydrogen converstions and all the companies that sell kits are not selling them do to some legal reason. Could it be the oil companies own the pattens???
Anyhow, it looks like you can run either CNG or hydrogen in a conversion kit with little if any changes. You can still run on gasoline so not only do you get green fuel you get extended driving range.
Fueling can be done at home so you will have to figure out how to pay the hwy tax your self ;)
There used to be a company in Fla. that sold a conversion kit for CNG. But that was way back in the 70's. Back then it was a matter of feeding the gas to the carb. and sealing the edges or wherever the leak might go. Not all that complicated, but I didn't get one. They advertised primarily for clean air.
I don't remember their name or have any of their literature anymore.
Kalawang
More like if it will work in any vehicle. Sorry...I just read the first page and I'm skeptical that a "little black box" can create enough constant hydrogen be an effective suppliment of power to a 5000lb vehicle.
I'm skeptical about that hydrogen website you posted...
IMHO it looks like a scam... there is no contact information to the website, no reputable sources stated, ect...
I like to see it this way, if toyota, honda, ford, ect... spend millions of dollars on hydrogen research, and you got these people selling a device for $300.00, wouldn't you think they would install it on vehicles by now??
To me, this would fall in the category of "fuel line magnets, splitfire spark plugs, so called superchips, oh and lets not forget the famous TORNADO :D"
I hope i don't sound like i'm trying to put alternative fuel technology down, but i'm just really skeptical when it comes to devices like the "little black box"... besides, i have seen "plans" for a kit that is similar to this selling on ebay for $10...
As a previous post stated, for alot of the alternative fuels (lpg, ect..) we should take into consideration that we are trying to propell a 6,000lb. vehicle which uses alot of energy... Looking at gas prices, i would have to say even a better alternative fuel for the time would be ethanol. I'm not trying to promote this in anyway.
Yes, ethanol (e85) does have a lower btu content, but look at the current market. E85 i would say is more available than any other alternative fuels, it can be used with gasoline (it can mix), and it is cheaper. As gas prices almost hit 3.00, e85 in my area is in the $2.00 range.... when gas prices were in the $2.00 range before e85 was still in the $2.00 range.... At this point (same price for either fuel), i would prefere to use gasoline as it has a higher btu content, which will "make the fuel last longer" in simple terms when compared to e85. But right now as gas is almost a $1.00 difference, e85 is a better option as it is cheaper, even though it's lower btu content "won't make the fuel last as long as gasoline", but you still end up saving $$$ in the long run if gas prices are up. I hope i'm being somewhat clear :D
At my university, we specialize in alternative fuels, and ethanol is currently being heavily funded... There are companies around the area that sell E85 conversion kits, i'm sure a web search will bring some up. Compared to LPG, CNG, ect... i would say e85 to be the best choice, at the moment. With a conversion kit, you can still use gasoline however you like, but you just now have the option of 85, giving you a choice now....
Hope this clears things up.
Try this.
www.mogas.ca
It is a canadian company. There really aren't any U.S. companies that do CNG conversions any more. The big three auto manufacturers succesfully lobbied the government to stop anyone but an auto manufacturer from installing a system. That is for comercial purposes though. If you wanted to put one on yourself, there is nothing stopping you but the $$$. It will probably cost you around $2000 to $3000 to do a conversion yourself. More if you have someone else install it. And good luck finding a shop that wants to tackle that since most mechanics here in the U.S. have never seen a CNG system. This would be for a dual fuel system. That means that the truck will run on either gasoline or CNG. You just flip a switch on the dash to select a fuel or the system automatically switches for you when one system or the other runs out of fuel.
You can fuel at home, but you need a compressor station. Thats more $$$. The best bet would be to find a comercial place that will sell you CNG. Not many CNG stations around in most places, but I hear California has several. You are going to have an even harder time finding some place to fill up with hydrogen. But if you can find a place, the system is the same. Just one BIG word of caution. If you want to use hydrogen, use ONLY hydrogen. If you want to use CNG, use ONLY CNG. DO NOT mix!!!
If you want to do it, give the guys at Mogas a call or an email. Tell them what you have and what you want to do and they will put together a system for you. I was going to do it but my wife vetoed it because of the cost. I can buy CNG at work for the equivalent of $1/gal. I figured the system would pay for itself in about a year but :princess: didn't see it that way.
Oh well. :rolleyes:
my only input would be that they are building MANY ethanol plants in the US (one 15 miles from my house in GA) so that should tell you something. For the money, I would swap in a greased diesel and call it a day with free fuel vs lower cost.
Now we just need someone to engineer a system so that our trucks can actually run ethanol and not throw a code.
With the lower btu of ethanol, it will actually cost you just as much or more than running gasoline. Less btu = less power = more foot in the throttle.:doh:
A conversion system is easily possible...
I'm currently out here in minnesota, like i stated before my university specializes in ethanol research. There are a few companies around here that can do conversion kits, it's only a matter of contacting them.
Off the top of my head, i don't know the names, but a conversion kit would just replace components that would get "eaten up over time" by ethanol, and of course, i would see a ecu mod so it properly adjust for the ethanol in the fuel...
Hopefully you guys know that 10% ethanol is used in most gas stations nationwide... my university is trying to push that limit to 20% in it's current research... that would be cheaper gas prices. Only problem is just the higher the ethanol level, the more prone some materials will be to getting eaten up by the ethanol (alchohol) level.
True, lower btu...
But if gas prices keep going up, the low ethanol prices will compensate :D
Edit:
Now that i'm thinking about it, i should look into an e85 conversion kit for my senior design project :idea:
Well, if anyone does the engineering for a flexfuel upgrade, I'll be interested in that (so long as it doesn't cost too much so the :princess: vetoes me again). I would love to run some American homegrown (fuel :D) in my 80. Oh.. yeah I know that most gas contains 10% ethanol. I also read somewhere that almost all vehicles will run just fine on a blend of up to 20% ethanol but the auto manufacturers will only warranty a vehicle that is not flexfuel on up to a 10% blend. Getting them to change will be the greatest challenge to making 20% a viable alternative for the masses.
Got a reply from http://hydranox5000.com/ , they said most suv's get a 10 to 20% increase in mpgs.
It would be nice is it works but like others said, looks like a scam. If there was more info on the company I would give it a try.
I would like to run on hydrogen or cng not either or added to the gas.
If fuel is $3.5 for a year, my cost to drive to work for a year will be $8,555.56
Thats just work driving, add in fun driving it gets $$$$.
How do I convert from therms to gallons so I can see how much cng cost per gallon?
This has got to be a scam.
They're saying they use the car's generated electricity to generate hydrogen. Essentially, that means you're burning gas, using the energy to make electricity, using the electricity to split water into hydrogen, and then you combine them back together to make water again.
At each step of the way, you're introducing more inefficiency and power loss. There's just no way this would work.
T.
Actually It's alot harder than anyone thinks. Propane on the other hand is much easier. I work at a company that makes, Propane, CNG, Hydorgen vehicles.. There are drawbacks and problems to each fuel. The biggest are range and storage. We have manufactured vehicles for GM, Toyota, Suzuki etc. Also Federal emissions standards make it impossible to make a single conversion kit for all platforms.
Hydrogen is not a fuel source, there are no large masses of it available, it must be made and it takes energy ($) to make it, there is some math in another thread that breaks it down, not gonna work.
LPG (propane) makes sense in Europe as it is cheaper there than petrol due to the high price of gas over there, some over there have made the conversion, here not so,
I have not looked into CNG (natural gas) , if it truly is cheaper per mile traveled you have my attention.
