HVAC Blend Door
Nashville, TN
I am in search of an HVAC Blend Door for my 2007 GX470.
Varmints ate mine. The actuator is fine.
Should I just patch it, or replace it?
PS: The tree rats were humanely treated and surrendered to a wild animal rescue.
I'd personally pull one out of a GX in a salvage yard and replace it. But, I'm not sure how much work it is to get the door out of the air/blend box. It could just come straight out, or it could require a dash removal.
Thanks, I found one, yesterday. I'm waiting on some foam for the seals, prior to installation.
Everything I found says you have to take the dash out.
I was able to flex the door enough to pop it out with a trim removal tool (https://tinyurl.com/AmazonTrimTool).
