This works for 93-97 80 Series.
Final tweaks and changes made. I moved to 1/4" thick ABS for the mounting plate and have decided to allow each person to order as little or as much from the kit as they like, essentially once you pick the mounting plate, you can just add from there. Options will include tinned marine cable, fuse or circuit breaker, six or twelve circuit fuse block and an option for the circuit breaker mounting plate. You can see the circuit breaker mounting plate mentioned earlier in the thread. Here are some pics of the mounting panel with the six circuit BlueSea fuse block mounted. Remember, just is just inside the drivers kick panel slightly above and to the left of the dead pedal. The mounting plate is pre-drilled to allow easy mounting inside the truck along with pre-drilled holes for both the six and twelve circuit fuse block. There are also two holes at the top allowing you to zip tie the wiring, securing it just after the fuse block. Stainless mounting hardware will be included.
The mounting plate is also very easy to drill and if you pilot it, mounting other things to it will be really easy. I like the idea of mounting relays and other things if you don't need the fuse panel there.
I will have it listed for order on the site early next week.
